How do you nest the rope molding into the crown rabbet? I tried selecting the crown as the top molding and the rope as the mid molding but it keeps the rope tight to he cabinet. Someone give me a clue please. Thanks
You will need to use the load item dialog box, select molding, and then give it the dimensions and miters. this will insert them like a cabinet. Then you can rotate and position them as needed. Once you do that, you will need to associate them to the cabinet and then save the cabinet.
