Just wondering if there any chance soon that we could get what thickness tape goes on a part on a label. When we run white board jobs there might be serval jobs in that nest and be quick and less waste if we could have on the label what thickness tape goes on. 1mm and 2mm tape is what we use
Yes, this is something we have been planning to implement for quite some time. The hold on the development has been due to the need to implement customizing the label layout. This will allow a user to adjust for different size labels as well as add/remove parameters without the need for Crystal Reports. This development effort is taking some time. Thank you for your patience.
Hi Larry,
This issue is pretty important and I can understand the complexity of creating this report without using crystal reports. Could you not deliver this result in two stages? Stage one you have to use crystal reports to get the edging thickness, edge colour and edge finish. Stage two you have a built in label designer.
If this label had a built in bar code like the offcuts has printed that we could run a scanner over at the edgebander that would be mickey mouse.
From memory I think we have this information already going into ecabinets so it may not be that difficult to get it to show up on the label?
Sorry for harping on this but we have just come from a legacy system with this info available to us on the labels to Ecabinets system so feel at a loss.
