More problems back in 5.41
DanFecteau
I got back to 5.41 cause of the problems I had with group doors in 5.44. I used the repair to go back to 5.41 and now all dxf that comes from easy link do not want to work. I always get something like "material should be at 0.000 thickness". Is 5.44 getting fix soon ? If not what should I do ?
Justin Melhiser
Re: More problems back in 5.41
Dan
Send in your dxf file. Have you ran this dxf file before?
DanFecteau
Dxf is not the problem... I went to 5.44 and got back to 5.41 using the Repair, do you think that the problem might have happen during the process ?
Daniel Vonderheide
If you ran the 5.41 install and used the repair choice you shouldn't have any issues loading dxf files in Control Nesting. I would suggest running the 5.41 install again to make sure it repairs properly.
Dan,
Not sure where your at with your DXF situation? Are you now able to nest your dxf files since reverting back to 5.41? In any case, if you've stepped forward to the latest version, as long as you've kept the previous install, you should be able to run the REPAIR option to revert back to previous version.
If your still having issues, please contact our Software Support group (program@thermwood.com or 1800 221 3865, ask for software support) directly so we can work out any details. As far as 5.45 release, I've not recieved an exact time for it's release, but as usual we will try to get it out as soon as we can.
