Glitch with Hardware Hole Pattern
Jamie Glenn
I cut a cabinet out on our Thermwood CNC and noticed the partition did not have the slide holes on both sides of the partition. (There are two top drawers in the cabinet). We have not had problems doing this in the past. I checked my cabinet in the line drawing editor for depth on the holes and it was .26. The hole pattern we use is supposed to be .5 deep. So, I went and checked the hole pattern again. It was correct at .5, Hmmm. I took the cabinet back to the cabinet editor and deleted the slides, patterns, and partition. Then I replaced them. I took the cabinet to the line drawing editor and re-checked the depth of the slide holes. They were correct at .5. Problem fixed I guess. Went back to the room and replaced the cabinet. Nested it and checked the partition again. The holes were .26 still. ????
Also, when it cut the first time, the CNC usually askes us to do a flip operation on holes less than .375, it didn't this time, why not? Next, I tried re-booting my computer and re-peated everything above. Same problem keeps popping up. I want the holes to be .5 not .26. Help please!
- Damon Nabors
Justin Melhiser
Re: Glitch with Hardware Hole Pattern
Jamie
Please post the job or email it to me. I would also liek to have the pattern and slide information as well.
Justin Melhiser
Jamie
Please email me you export file from CN. If you need any help getting this please contact me.
