Cabinet wall height
Cabinet wall height
I am designing a kitchen with 108" tall walls. I did all the upper cabinets then realized my top cabinets were set to low. I went to settings and changed the top cabinet wall height to 103 but the cabinets did not move. Is there a way to raise them to the proper height without starting over?
Re: Cabinet wall height
Go to the wall view, make sure the cabinets you want are associated to that wall. Highlight one of the cabinets and in the upper left corner are the distances from the walls and floors. Change the numbers there and the cabinets will move to where you want them.
Dell Precision 7710
NVIDIA Quadro M3000M
512 GB PCIe NVMe - M.2 SSD
Win 7 Pro 64-bit
http://lrgwood.com
Win 7 Pro 64-bit
http://lrgwood.com
Thanks for the help, but I am not finding it. I associate the cabinet to the wall go to the left corner and a box opens from the side but I don't see the cabinet height. I do have a wall height and a height from floor which is 4" so that must be the toe kick. More help please
Click on the number that is the hieght from the ceiling. It should highlight and now you can change the number. Change it so it palces it in the correct position.
Dell Precision 7710
Win 7 Pro 64-bit
http://lrgwood.com
Win 7 Pro 64-bit
http://lrgwood.com
- George Davidson
Hi Bob
Have you looked at this
CUSTOM LAYOUT PART 3 - INSTALLING CABINETS AND ASSEMBLIES
Thanks guys, I didn't have them associated to the wall. Once I did it worked fine.
Agian THANKS
Agian THANKS
