back inset
Darren Harvey
back inset
Post by Darren Harvey »
i need to have a back inset with a cabinet. and i keep getting a message saying i can't be done. can this be done? if so how do you do this. thanks darren
console 1.hsf
(240.02 KiB) Downloaded 533 times
JohnLashuay
Re: back inset
Post by JohnLashuay »
Darren,
Are you trying to inset the back on an angle?
http://www.rylexonline.com
Thermwood CS 43
Todd Miller
Re: back inset
Post by Todd Miller »
Darren,
If you want to inset the back, goto construction settings, then the "BACK" tab. Set the "BACK INSET" to whatever you need it to be. If you want to have the part rotated to match the angle on the end panels, you may want to use a stretcher for the back panel. See pic below.
If this is not the answer you were looking or you need further assistance, for let me know.
back stretcher.JPG (47.36 KiB) Viewed 4361 times
Darren Harvey
Re: back inset
what i was doing was giving the deck a back inset then the back a back inset. that's where i was getting the problem. then i left the deck without an inset and gave the back the proper inset, and everything fell into place. thanks darren
