Gary Puckett
Posts: 1324 Joined: Mon, May 19 2008, 1:39PM
Company Name: The Woodworkery
Post
by Gary Puckett » Sun, Jan 18 2009, 10:00PM
Does anyone know if you can edit a cutout already put in a wall?
Damon Nabors
Posts: 923 Joined: Wed, Apr 05 2006, 5:50PM
Post
by Damon Nabors » Sun, Jan 18 2009, 10:04PM
Yep
Damon Nabors
Gary Puckett
Post
by Gary Puckett » Sun, Jan 18 2009, 10:06PM
OK,
would you care to share that information?
Damon Nabors
Post
by Damon Nabors » Sun, Jan 18 2009, 10:18PM
Gary, you just asked if the wall could be edited, what are you trying to do with the wall?
Damon Nabors
Gary Puckett
Post
by Gary Puckett » Sun, Jan 18 2009, 10:22PM
Damon,
I made a cutout in a wall and I need to edit the hieght. I would show you but I can't get a jpeg.
But what I have to do is edit about a 1/4 " from the height and it is way to complicated to redo thecut out.
Gary Puckett
Post
by Gary Puckett » Sun, Jan 18 2009, 10:25PM
Wait I can show you
Damon Nabors
Post
by Damon Nabors » Sun, Jan 18 2009, 11:21PM
Your just going to have to delete the cut out. How can it be that difficult to redo one wall. X=?,Y=? at the lower corner and x=?,Y=? at the top opposite corner and viola, You have a rectangle ready to cut out. Then do another rectangle below that one and cut it. That should be your wall. Maybe a minute or two tops. You have been doing this long enough now that you can do it.
Damon Nabors
Gary Puckett
Post
by Gary Puckett » Mon, Jan 19 2009, 8:34AM
Damon,
All I asked was if a wall that already had a cut out in it, can that cut out be edited, I know I can redo the wall
Damon Nabors
Post
by Damon Nabors » Mon, Jan 19 2009, 8:41AM
Sorry Gary,
I don't think you can edit the existing cut out by making it smaller. You would have to re do the cut out. Now on the other hand, If the cut out is not large enough, You can edit it by drawing another box or rectangle and removing more material.
Damon Nabors
Posts: 4764 Joined: Mon, May 09 2005, 7:33PM
Post
by Kerry Fullington » Mon, Jan 19 2009, 8:43AM
Gary,
It sould be best to remove the wall cuttouts and re-do them correctly. You can make a cut larger by cutting more of the wall but you can't make the cut smaller.
Damon Nabors
Post
by Damon Nabors » Mon, Jan 19 2009, 8:50AM
Gary, one thing you can do. Go back and draw a smaller box tracing over the existing box if you want it smaller. and then delete the larger one underneath if you need it to be smaller. That way you can follow in your footsteps.
Damon Nabors
Posts: 1585 Joined: Tue, May 17 2005, 1:16PM
Post
by George Davidson » Mon, Jan 19 2009, 12:14PM
Hi Gary
You can take the wall into line drawing editor
Shot 3.jpg (48.93 KiB) Viewed 14368 times
Shot 4.jpg (33.93 KiB) Viewed 14368 times
Gary Puckett
Post
by Gary Puckett » Mon, Jan 19 2009, 2:01PM
Thanks George,
I can go in and just delete the rectangle that is wrong and replace it with the correct dim.
Leo Graywacz
Posts: 641 Joined: Tue, Jan 16 2007, 7:56PM
Post
by Leo Graywacz » Tue, Jan 20 2009, 9:03PM
Use the Add Geometry option, it is the last option. If you want to erase 1/4" of the top just make a rectangle that overlaps the top area by 1/4". Make sure that some part of the new area is outside of the old area or you will not be able to select it by itself. Chose select and then highlight the new rectangle, choose Add Geometry and it will add the new wall area in your open hole.
Dell Precision 7710
NVIDIA Quadro M3000M
512 GB PCIe NVMe - M.2 SSD
Win 7 Pro 64-bit
http://lrgwood.com
Leo Graywacz
Post
by Leo Graywacz » Tue, Jan 20 2009, 9:21PM
Fun stuff you can do with add geometry.
One thing I noticed is you cannot make a floating section. If you try, the whole wall disappears and the cutouts remain.
Dell Precision 7710
Win 7 Pro 64-bit
http://lrgwood.com
