Whenever I select the Door/Drawer Front Designer and select either Doors or Drawers followed by selecting any of the types (Conestoga, Slab, etc.) the software immediately crashes. I did notice that there seemed to be some sort of update earlier today when I first opened the program. Is something in the software broken? Is anyone else having this same problem?
Joe
I can not reproduce this. Could you give me the steps from start to finish? Do you have a certain cabinet or job file loaded when you go to the Door/Drawer Front designer?
I had a similar problem. I was using two monitors. I found that e cabinets crashed all the time for me until I went into the windows set up
and told it not to extend my desktop to the second screen.
Now, I have no second screen but ecabinets has not crashed once since then.
Thanks guys. My assumption at this point is that one of the programs I recently installed wrote over the mfc80.dll file or ntdll.dll file, since this is what the crash dialog is complaining about. (It complains twice as it goes down in flames...) I'm figuring I will need to re-install the ecabs software.
The steps for me to cause this are:
1) Start the program.
2)Select the Door/Drawer Front Designer.
3)Select any of the sources.
The program then crashes.
It's been so hot lately that it may be that my computer is overheating. I sure hope this heat wave breaks soon.
I noticed that sometimes when you run the update it does not seem to install completely.
I usually recommend that you save it to you desktop and then you run it.
It may ask you to MODIFY , REPAIR OR REMOVE. Try the Repair.
Well, I reloaded the software from the disk and then reloaded build 4, but I'm still having the same problem. The program crashes complaining about mfc80.dll 8.0.50727.1833. Is this possibly the wrong version for eCabinet Systems?
Yep, and it's obviously a DLL that eCabs uses. I'm wondering if eCabs just has a problem with this version of the DLL. I'm also going to make a guess that eCabs is defaulting to run the latest version of the mfc80.dll and it's not quite 100% compatible with this 1833 version.
You are right Dan, but unfortunately I need the program running since I'm in the middle of a project. I'm using XP.
Thanks for your concern! I will keep the fire extinguisher handy and a bottle of cheap wine in case I need to drown my sorrows. Oh what the heck, I can use it to celebrate as well.
