Hello All
I am working on a bath vanity.
For some reason it keeps crashing when I apply doors and drawer fronts.
It will go through the process of saving itself after I add a door say and then it will stop where is processing the edgebanding, then a pop up will occur
saying "The parameter is incorrect". I have never had this before.
The only thing I did differently this time was to create a stretcher to become a backer for a false drawer ( the drawer front attaches to it ).
When I created the stretcher I had to rotate it as the tenons were biting into the front of my edgebanded case.
Does anyone have any ideas? I am trying to get this out to my cnc guy.
Steve WIlliams
Re: "The parameter is incorrect"
Hi Steve,
can you post your files on the forum!
Nemanja
Nemanja
- Company Name: Richmond Cabinet
You don't need to rotate the stretcher. In streatcher editor, select the stretcher and click Construction Settings. Select Construction Parameters for up-down stretchers. Select Tenon Front Side. Your problem should go away.
Dave Egnoski
Richmond Cabinet & Millwork
Thanks David
