Any ever done this
Gary Puckett
Company Name: The Woodworkery
Any ever done this
Post by Gary Puckett »
I have been trying to put a wall tile image on a 45 degree with no luck. Has anyone ever done this and please explain the procedure.
Leo Graywacz
Re: Any ever done this
Post by Leo Graywacz »
I would probably cheat. Take the image and put it into my photo editor and them rotate it 45*. Resave it as a different name, 'original_file_name 45'. The you just need to choose that tile.
If you are trying to make the whole wall this way it may be more difficult.
Dell Precision 7710
NVIDIA Quadro M3000M
512 GB PCIe NVMe - M.2 SSD
Win 7 Pro 64-bit
http://lrgwood.com
45 Tile.jpg (82.05 KiB) Viewed 16303 times
Gary Puckett
Well this is what I get if take the image and rotate it 45 degrees I can't get rid of the 4 white corners and if you use it as a wall image you get the tile and the white boarders that then look like tile.
drift wood 2 45.jpg (7.89 KiB) Viewed 16342 times
Gary,
There are a couple of images in the STONE directory in eCabinets that are set on a diagonal.
Gary,
I did this one by creating a display cube and using a square tile pattern then rotated the cube 45 degrees. I then made a jpg of the cube and cropped that in Irfanview back to a ninety degree image. I then used that image on a new cube. You could do this with any tile pattern.
Gary Puckett
Thanks Kerry,
But thats a lot of work. I just need to figure out how to get the four white corners to become the tile image and it will work.
I was waiting to see if you were going to pull that off Kerry. :)
Gary do you have a picture program
I have Screen Shot-8 program it works for me.
Here is some concrete with white around it with the program I took the white out
Gary Puckett
George,
Yes I have 3 photo programs but all they can do is crop a square or a rectangle.
Is this what you want
Gary Puckett
No, I need this without the white corners
drift wood 2 45.jpg (7.89 KiB) Viewed 16275 times
Leo Graywacz
I don't know if eCabs can handle it, but if you save it as a GIF with the transparency set for white then the object will show up without the with borders.
Dell Precision 7710
Win 7 Pro 64-bit
http://lrgwood.com
Brad McIntosh
Company Name: CNC Automation
Post by Brad McIntosh »
Is this what you are looking for?
Drift Wood "Tile" at a 45 degree angle with corners "filled" with replicated pattern.
drift wood 3 45.jpg (7.06 KiB) Viewed 16235 times
Brad McIntosh
CNC Automation
Twitter: @bmcncautomation
Gary Puckett
Thats it how did you do it?
