Unable to Delete Stretcher
In the stetcher editor, on a cabinet that I had downloaded from one of the libaries, I couldn't delete one of the drawer stretchers. I could highlight it, but when I tried to delete it, it stayed. With it highlighted, I'd pick 'adjust stretcher', and the image, and adjustments would come up for the rear nailer instead. Not clear on how to get rid of it.
Re: Unable to Delete Stretcher
Since I have no idea what this cabinet looks like I will guess that you are actually trying to delete a shelf or a partition, so you need to select that editor.
Joe
Joe
CFT411 http://www.cft411.com
Thanks, Joe. It was a 4" front stretcher located below the top drawer, and that did work to delete it in the shelf/partition editor.
FYI .. You cannot use a stretcher to creat a hole for a drawer or a door. You need to use a (fixed) shelf with a large back offset (usually).
Dell Precision 7710
NVIDIA Quadro M3000M
512 GB PCIe NVMe - M.2 SSD
Win 7 Pro 64-bit
http://lrgwood.com
Win 7 Pro 64-bit
http://lrgwood.com
If you hover over any object, such as a shelf or a stretcher the software will tell you what kind of part it is along with all of the other information you need to know. Your "stretcher" was actually a fixed shelf with a back inset. The parts need to be operated on in their related sub-editor.
Joe
Joe
Thanks again, Joe.
Nat
Nat
