can anyone tell me how to make a double panel door with the door/drawer editor. I have a 70 inch tall door that I am going to be putting a mid rail in and wanted to be able to draw that up. any help will be greatly appreciated. thanks.
Sorry, eCabs does not currently support multi panel doors.
For display purposes, I would place one door on the lower half with a top inset/reveal equal to the size of the top panel. Then manually place a door as a display object (about 2\" taller than the opening) so the lower rail and upper rail, merge as one, creating the appearance of one door with a mid rail.
Be sure the display door is associated to your cabinet or you will loose it when you save.
Alternatively, if the door style used a flat panel, you could place a display board or panel on it to simulate the mid rail.
Does the same still hold true in V5 or can multi panel doors be created now? I have used display cubes in the past and it works fine, just a little cumbersome.
