Load the attached job, simply a small empty room, which I created from a freshly-started eCabinets. Hit the Render button and it crashes.
To get it to render, you must delete walls #4 and #5. Deleting either one alone won't fix it. The only thing that is different about either of those walls is that #5 was created after #4 which of course caused the build direction to be reversed (it alerted me to this fact, as usual).
The steps taken to build the room were placing the walls, then changing the wall heights from 2438mm to 2440mm one at a time, then doing the cutouts in the walls, then placing the light fixture.
Never had this happen before. I thought the programmers might want to have a look and see what is causing it
New empty room crashes on render
- Jeremy Schiffer
CS-41 4x8
CS-45 5x12
CS-41 4x8
CS-45 5x12
- Jeremy Schiffer
Re: New empty room crashes on render
Duh. Forgot to attach the file.
- Attachments
- ivie.esj
- (164.02 KiB) Downloaded 298 times
CS-41 4x8
CS-45 5x12
CS-41 4x8
CS-45 5x12
