Part Editor Demystified
Many (most?) users have trouble creating edge profiles in the Part Editor.
One reason users experience confusion and frustration in this area is that the part cannot be rotated within the Part Editor. Because of this, you have to create tools with different orientations and select the correct tool path starting point to achieve the desired results. Sometimes the material being profiled will be blue, other times it is yellow. Sometimes you need to use a right offset, other times a left offset is needed.
I have created a short document that should help take some of the mystery out of this operation.
I hope this helps!
Part Editor Demystified.pdf
(56.7 KiB) Downloaded 598 times
Michael S Murray
Re: Part Editor Demystified
Post by Michael S Murray »
Well, Thank You Dan, that is useful info.
Looks like even a guy like me might have a chance at understanding that!!
Mike Murray
mike@versatilecabinet.com
Michael S Murray wrote:...Looks like even a guy like me might have a chance at understanding that!!
I made it so I could understand it then everyone else should have no problem with it. :wink:
Chris Harmon
Company Name: Azure Cabinets
Post by Chris Harmon »
Thanks Dan,
Great document, could not have came at a more incorporate time.
Gary Puckett
Company Name: The Woodworkery
Post by Gary Puckett »
Thanks Dan for posting that information.
That has always confused me on where the cutter was cutting
Gary Puckett wrote:...That has always confused me on where the cutter was cutting...
You are not the only one confused by edge profiling Gary. This is the method (and same tools) I used to figure it out way back when. The only problem is, if I don't use it for a while, I have to figure it out all over again.
Al dedenus
Country: NEW ZEALAND
Post by Al dedenus »
Thanks Dan.This is one area that I'm totally lost in,you've been a great help :D
