editing assemblies from CL
Al dedenus
Country: NEW ZEALAND
Post by Al dedenus »
had to edit an assembly from custom layout (single drawer unit with open cabinet above for a microwave) took it to the cabinet editor>door drawer editor-where I changed the drawer front>straight back to CL.It put the drawer unit half way inside the open unit and placed the two of them half way through the floor and part way into the adjoining cabinet.Do you always have to go back to the CE before going back to CL when editing assemblies???? Never had this problem with single cabinets :?
JohnLashuay
Re: editing assemblies from CL
Post by JohnLashuay »
Al,
It sounds like you may have moved the cabinet while it was in the CE. If that is the case then it will be reflected in the CL. I have done this as I have hit the wrong keys as I have zoomed in and it then resulted with my cabinet being in the wrong place in the CE.
Hope this helps!
-John
http://www.rylexonline.com
Thermwood CS 43
JohnLashuay
Al, I may have misunderstood you question. :oops:
Did you go directly from the Door/Drawer editor to the CL?
Thermwood CS 43
Al,
Send this to the programmers using feedback with details on how it happened. This sounds like a re-occurring problem where drawer boxes jump out of the cabinets.
Joe Dusel
Post by Joe Dusel »
It sounds like a problem with the transporter. Better have Scottie (Vaal) take a look at it. 8)
Joe
CFT411 http://www.cft411.com
Al dedenus
yea John went directly from the door editor back to the custom layout and no did't move it when in the cab editor.will send to the programmers. Thanks guys
