Metabox drawers HELP
Iain Hall
Post by Iain Hall »
Here's what I am trying to do have a three drawer base unit It will have 1 -22x 3.5" and 2 -22"x6" metabox drawers in it I would like to be able to use this unit as a seed cabinet and have the cost and quanity of the different metabox drawers tracked as well as have the bottom and back pieces be included in the nest
Finally added more ram so system is fast just need to get me up the same speed.
Iain Hall
Woodwright Cabinets
Iain Hall
Re: Metabox drawers HELP
Post by Iain Hall »
Think I got it is this the best way to do it
base 3 drawer metabox.hsf
(734.02 KiB) Downloaded 1184 times
Iain Hall
Woodwright Cabinets
FredHirsch
Post by FredHirsch »
Ian,
Looks good to me. You might want to put a little gap in there between the bottom of the drawer box and the deck/stretchers (unless you have already accounted for this in the hole patterns). I think BLUM likes a 1/8 gap in there for movement. We are switching to the grass system so I'll think I'll have to come up with some new hole patterns for for that system. Did you draw these hole patterns yourself?
Thx
Fred
Fred Hirsch
jason galbraith
Country: AUSTRALIA
Post by jason galbraith »
I'm not sure if it's the same, but the downloadable library has a very similar system in it that you could use, and also has the drilling in the back off the draw fronts for the knock in clips
www.eastcoastultimate.com.au
Chris Harmon
Company Name: Azure Cabinets
Post by Chris Harmon »
The downloadable library that Jason is talking about is the System 32mm Frameless.
One tip that might help is on Blum metabox drawers the mounting hole reference points are different on tall drawers than short drawers plus the spread between holes changes on tall drawer fronts. So if you are manually drilling your drawer fronts you will have to change your set-up between different size drawers. If you use Grass Zargen drawers the reference and spread is the same know matter which size drawers you use. So you do not have to change your set-up. This can save a lot of time and mistakes if you are doing a large number of drawers.
Iain Hall
Post by Iain Hall »
No I didn't draw the holes myself took the slides from the Blum hardware choices
Thank you all for your input
Iain Hall
Woodwright Cabinets
Nat Wheatley
Post by Nat Wheatley »
How do I open the posted file(HSF)?
Gary Puckett
Company Name: The Woodworkery
Post by Gary Puckett »
First save the file to your desk top then Go to the display part editor, and click Load STL/HSF find the file on your desk top and click on it
Nat Wheatley
Once I open it in the display part editor, how do I get the drawers to show?
Chris Harmon
Nat how I loaded Iain's HSF file is:
1. I have a file called Downloads in my Cabinet directory. You can create a download file by just saving any cabinet and naming the directory downloads.
2. I saved the HSF file to that downloads file. You can then open the file like any other cabinet.
3. How to get the HSF file to the downloads file.
1. I first save the HSF file to the desktop
2.Click on My Computer
3.Click on C: drive
4.Click on Program Files
5.Click on Thermwood
6.Click on Ecabinet Systems
7. Click on Cabinets
8.Click on Downloads
9. Drag and drop the HSF file in to the downloads file
The path should look like this C:\Program Files\Thermwood\eCabinet Systems\cabinets\Downloads
That is how the file structure is on my computer system. It should be that way on most computers. I hope this helps. Let me know.
Nat Wheatley
That worked. Thanks Chris.
