Thermwood 80 ES
- Company Name: Can-Am Specialties
Thermwood 80 ES
Does anyone out there run this exact machine that would be willing to answer some questions? We purchased the router used, and are trying to get started, but we have encountered a few functionality issues.
Re: Thermwood 80 ES
James,
I would recommend you contact Thermwood Service dept. and have a tech travel to your facility to go through the machine and insure that it is functional and correctly setup.
Contact info:
email: service@thermwood.com
phone: 1800 221 3865 (ask for field service dept.)
Thanks!
Contact info:
Thanks!
Re: Thermwood 80 ES
Hello James,
I've continued to look into the particular machine serial number in which you've supplied and there is no macro files here at Thermwood. It is likely that this machine shipped from the factory without macros and that the macros were made per customer. Machines of this time were typically sold and setup per customer and macros added once machine arrived to customer.
I did resent the PDF for the 91/9100 user control manual and was wondering if you have recieved it? This is likely going to be your best reference as you try to get your machine running.
