I think I have found a work around for blind corner cabinets in e-cab. The only problem is that the software flips the tenon on the blind side thus creating a flip operation on the machine. eg. tenon on the top side on one end of the shelf and on the bottom side on the same shelf. I have attached the cabinet. Is there anyway to avoid this.
Why use a corner cabinet as the starting point for this cabinet Steve? Use a Std Upper and change the settings to match your needs. Add an up-down stretcher for the return and you're set...like this:
Blind Corner Upper Frameless.jpg (13.49 KiB) Viewed 3249 times
