Not sure if this is in the right place but a little while back the boys at thermwood changed how we print from the machine. When the change was made we lost the ability to print out just bar codes. Is there anyway we can get that back. We often print just bar code for the offalls because we do not need all the labels for the cabinets or components.
thanks
Steve
Printing Labels
Steve Detina
- Company Name: Silhouette Custom Cabinets
FredHirsch
Re: Printing Labels
Steve,
I'm with you on this... We've been throwing away a lot of labels just to get that off-fall label.
Fred
Fred
Fred Hirsch
- Jeremy Schiffer
Re: Printing Labels
You can still print only the barcoded labels, but it's a bit confusing now. When you're at the print dialog, you have a button that says "Select file" or something similar. Click it, and you'll get a file list of the different labels. Look for one that has the word "barcode" in it, along with the number of the label you're using.
Hopefully this gets you going... I'm not at the machine right now so I'm doing it from memory. (And my memory SUCKS. LOL)
CS-41 4x8
CS-45 5x12
CS-41 4x8
CS-45 5x12
FredHirsch
Re: Printing Labels
Jeremy,
Thanks for the heads up.... I was a bit surprised that it could have been removed.
Fred
Fred
Fred Hirsch
- Brad McIntosh
Re: Printing Labels - Off-Falls Only
Here is a label formatted to print ONLY OFF-FALLS...
>> No warranties are expressed on implied. The label has been tested but it's use is your own responsibility.
Cheers!
- Download and save the attached ZIP file to your Desktop.
- Unzip the contents and copy the "30252_Address_Barcode_Off_Falls.RPT" file into the "C:\Rolling Nest\Labels\" directory on the Thermwood controller.
- Make sure to select this new label format to print labels with barcodes for OFF-FALLS ONLY.
Cheers!
- Attachments
- 30252_Address_Barcode_Off_Falls.zip
- Standard 30252 Address Label with Barcodes for OFF-CUTS ONLY.
- (4.83 KiB) Downloaded 998 times
- Brad McIntosh
Re: Printing Labels - Off-Falls Only Updated
I have updated the above "custom" label I had posted previously to indicate the SHEET and "Part #" associated with the Off-Fall.
>> No warranties are expressed or implied. The label has been tested but it's use is your own responsibility.
(If you had tried out the earlier one, make sure that you over-write it with this newer version.) - Make sure to select this new label format to print labels with barcodes for OFF-FALLS ONLY.
- Attachments
- 30252_Address_Barcode_Off_Falls-2.zip
- Rev 2- Standard 30252 Address Label with Barcodes for OFF-CUTS ONLY
- (4.97 KiB) Downloaded 996 times
