'You can only edit one part at a time in part editor'
Nat Wheatley
I get this message all the time when I select a part, and try to bring into PE. I unselect everything, select, what I believe to be, a single part, try again, and often get the message again. I there a way to select parts that avoids this? Thanks.
Leo Graywacz
Re: 'You can only edit one part at a time in part editor'
I've notice on occasion that when you select a part, the parts behind it can also get selected. If you can put it at an angle and be sure just the one part is selected you should be able to continue. It this is no the case then you might have a different problem.
Dell Precision 7710
NVIDIA Quadro M3000M
512 GB PCIe NVMe - M.2 SSD
Win 7 Pro 64-bit
http://lrgwood.com
Win 7 Pro 64-bit
http://lrgwood.com
