'Material not found'
I keep having odd materials surface when I try to load cabinets into the the cabinet editor. I get the 'material not found' error. It's the same material each time, but on different cabinets. I don't know where it's coming from, its not a material that I have used. How do I eliminate this? Thanks.
- DanEpps
- Company Name: Dan Epps
Re: 'Material not found'
Are these cabinets that you designed or did you get them from someone else? If it is a library that you got from someone else, you will have to add the missing materials when prompted. Before deleting the material from the database, load each cabinet in the library, change the materials and save it. Once you have all of the cabinets using that material changed, you can delete the material.
Thanks Dan.
Is there a way to change the door material, aside from redoing the doors?
