Is there a way to take the stock molding in eCabinets and modify them? Specifically I would like to use one of the Conestoga base moldings Product ID Colonial-Base-10 Cherry and make it 3.5" tall instead of the default 4.5" tall. Can this be done? If so, how would it be done?
Thank you!
Stock Molding modofications
- Kerry Fullington
Re: Stock Molding modifications
Donald,
You can't modify the stock moldings but to accomplish what you are wanting to do I always place the molding Where the distance from the bottom is a negative 1" and that will drop the molding that 1".
When you place your cabinet in a room that lower part of the molding will be below the floor line and not be visible, therefore your 4 1/2" molding will look to be 3 1/2".
Re: Stock Molding modofications
Thank you Kerry. I guess with software there are always work-arounds to accomplish the final outcome.
I'll do that and I think the customer will be happy with the results.
Thank you again!
Thank you again!
