Face Frames
Randy Rogers
Company Name: Randy Rogers Cabinets
Face Frames
Post by Randy Rogers »
Could someone please tell me how to change the width of the mid rails and styles.I have tried everything I know and can only change the outside frames.
Zach Froble
Re: Face Frames
Post by Zach Froble »
Randy,
There are two options I believe:
1. You have to change the sizes in the construction settings before you add them
2. If you have already added them you have to select them by clicking on them and then change them in the constructions settings.
Zach
Lyndan Designs
Machining and CAD Services
Re: Face Frames
You have to go to face frame editor
Randy Rogers
Re: Face Frames
I have tried the faceframe editor and it will only change the outer frames and not the mid rails and styles, have also tried highlighting them in construction settings. I can't figure out what I am doing wrong.
Alan Odell
Re: Face Frames
Post by Alan Odell »
Randy,
Go into the face frame editor. Highlight the mid rails or stiles you want to change then click on the construction settings icon. Go to page 2 and change the sizes. That should change them. You have to be in the face frame editor and have the ones highlighted you want to change to make it work. Hope you understand that not sure i do :?:
