Nesting Material issues
Tim Massa
Post by Tim Massa »
Would anyone know why the .77 MDF material in this batch of cabinets won't nest? I've looked at the material specs; no grain, 97" x 49", etc and can see no reason why it will not nest.
Likewise the storage cabinets' back will not nest although it's 46.5L in one direction and 68.55" wide. This material is also no grain so I can't understand why it will not nest correctly. Any help would be appreciated.
Thanks again,
Tim
Material quote 11 6 14.esj
(4.88 MiB) Downloaded 1172 times
Joe Soto
Re: Nesting Material issues
Post by Joe Soto »
Hi Tim, Looks like your material is .49" wide
Tim Massa
Post by Tim Massa »
Hi Joe,
Yes it is. I was working under the assumption that if the material has no grain orientation then the nest would put the rectangle shapes inside the material rectangle, going large to small rectangles, in the most efficient way.
Also, the .77 MDF material won't nest at all. AGain, no grain and parts are small enough to fit on the 49" dimension of the 49"x97" material spec. Nada on any .77" Mdf part nesting. Why an entire material won't nest is baffling.
Tim
Rick Deskins
Company Name: Thermwood
Post by Rick Deskins »
As joe stated, the .77 MDF material is set to 0.49" not 49". Change the material width to 49" and it will nest.
Rick Deskins
Tim Massa
Post by Tim Massa »
Wow, I stared at the answer twice and still read it wrong. My eyes must be composting with age. Thanks you Joe and Rick. Much appreciated
