Good morning
I have update control nesting on Friday to 5.02. Before this we did a job of 16 mm mdf doors that has cut throughs on the door (like slots) I have machine all those doors without a problem. This morning I had to cut an extra 4 doors of the same job. I load the job again choose the 4 doors nest it and write the cnc code. When the machine start to cut the slots (slots are 14mm wide)(i use my 12.7mm cutter) I seems it ramp in to the side and not on the length of the slot, and then it leave the one side of the slot with a funny cut out in it.
Since the update on Friday I allso see that it ramp in on the conrners now, and not where it use to ramp in.
Can somebody please help
Thank you verymuch in advance
Cut Throughs
- Company Name: Plett Roofing
- Country: SOUTH AFRICA
- Jason Susnjara
- Larry Epplin
- Larry Epplin
