Good morning
I have update control nesting on Friday to 5.02. Before this we did a job of 16 mm mdf doors that has cut throughs on the door (like slots) I have machine all those doors without a problem. This morning I had to cut an extra 4 doors of the same job. I load the job again choose the 4 doors nest it and write the cnc code. When the machine start to cut the slots (slots are 14mm wide)(i use my 12.7mm cutter) I seems it ramp in to the side and not on the length of the slot, and then it leave the one side of the slot with a funny cut out in it.
Since the update on Friday I allso see that it ramp in on the conrners now, and not where it use to ramp in.
Can somebody please help
Thank you verymuch in advance
I would like to avoid brushing this one under the rug. There were some changes in 5.02 that caused this issue. Would you please post your twd file with this cut out so that I can resolve it. Thanks!
