Machine cutting into part version 5-10
Mathieu Boileau
Post by Mathieu Boileau »
Hello,
I just upgraded rolling nest to version 5.10. I wasn't having this problem before and now for some reason the machine is cutting into the part. It cuts into the bottom corner cabinet top, shelf and deck. I have added an attachement of the .twd file and the .hsf file of this cabinet. Thanks
Error.zip
(510.18 KiB) Downloaded 500 times
Ryan Hochgesang
Post by Ryan Hochgesang »
Hi Mathieu,
Could you please send me a copy of the Export file created from Control Nesting? To make the export file, you simply next cabinet, then select the Export Button in the Main Control Nesting screen. Once you hit the export button, it will ask you where you want to save the file.
I would also like a copy of the actuall cnc file which is located in D:\\Data\\C:\\DATA\\ROLLING_NEST\\CNC-FILES directory on your control.
Mathieu Boileau
Here you go. Thanks for your time
Files2.zip
(589.76 KiB) Downloaded 532 times
Ryan Hochgesang
What version of Control Nesting were you running prior to this update? Could you please give me a call at 1800 221 3865 to discuss further details?
Ryan Hochgesang
Hi Mathieu,
We now have a new release of Control Nesting available on our web site, which will fix the issue your expriencing.
We appologize for any inconviences this may have caused you and thank you for your patience in this matter.
