Hello,
I just upgraded rolling nest to version 5.10. I wasn't having this problem before and now for some reason the machine is cutting into the part. It cuts into the bottom corner cabinet top, shelf and deck. I have added an attachement of the .twd file and the .hsf file of this cabinet. Thanks
Could you please send me a copy of the Export file created from Control Nesting? To make the export file, you simply next cabinet, then select the Export Button in the Main Control Nesting screen. Once you hit the export button, it will ask you where you want to save the file.
I would also like a copy of the actuall cnc file which is located in D:\\Data\\C:\\DATA\\ROLLING_NEST\\CNC-FILES directory on your control.
