Tabbing HELP Needed
Tabbing HELP Needed
I am \" TRYING \" to \" tab \" small pieces of 3/4 ply ......... In tab parameters, the use tab box is checked.....tab width is .5\", Part width for tabbing is to 40.0\", and my part lenghth for tabbing is set to 40.0\" ( pieces are 3\" x 35\" x 3/4\".......is there something I'm missing or maybe change another setting ......Thanks
- Mike Bowers
The tabbing is located in the setup of the rolling nest software out at the router....
I have never used the tabbing feature and without being at the controller I'm afraid I can't answer your question.
I'll be in the shop tomorrow, so if I remember I check the settings and see if I can give you a hand.
Mark
Mark
- Brian Shannon
- Brian Shannon
- Brian Shannon
Jim, I have never had to tab anything. Are you aware you can also skin and then cut through? If that wont work for your app. you might call in to thermwood tech and ask, they are great.
Mike Murray
mike@versatilecabinet.com
tabbing
Jim,
If you are still having problems with tabbing. Open Control Nesting on the SuperControl and select the \"Export\" option. This will create a database of files that we can use to recreate your Control Nesting settings.
If you will save that file to a disk (flashdrive,etc.) and include the .twd of the part in question then email them to,
program@thermwood.com
we would be happy to have a look at it for you. Please include your contact information in the email.
