I am \" TRYING \" to \" tab \" small pieces of 3/4 ply ......... In tab parameters, the use tab box is checked.....tab width is .5\", Part width for tabbing is to 40.0\", and my part lenghth for tabbing is set to 40.0\" ( pieces are 3\" x 35\" x 3/4\".......is there something I'm missing or maybe change another setting ......Thanks
Maybe you should post this question in the \"Thermwood\" forum to get better response. I have only tried the tab feature one time(RN 5. and had the same results that you did so I'm not much help either. I'm sure someone can help in the other forum. Sorry I couldn't help...
Jim, I have never had to tab anything. Are you aware you can also skin and then cut through? If that wont work for your app. you might call in to thermwood tech and ask, they are great.
I tried to tab once and got exactly what it implies. There is no real benifit as far as I can tell over skinning your parts. I've also noticed a better cut when doing a .015 skin rather than .05 default.
Jim,
If you are still having problems with tabbing. Open Control Nesting on the SuperControl and select the \"Export\" option. This will create a database of files that we can use to recreate your Control Nesting settings.
If you will save that file to a disk (flashdrive,etc.) and include the .twd of the part in question then email them to,
