Hi. My computer crashed and I'm trying to load the V5 disk. It goes so far
and then tells me my system has not been modified and to try again later. As you can probably tell I'm alot better at woodworking than at computers. I would appreciate any help anybody could give me.
Thankyou Pat
disk will not load
disk will not load
If you explore the Ecab disk you will find a folder labeled Clean. In that folder is a utility called eCabResetUtility.exe if you run this Utility it will reset your eCab configuration causing the the system to believe this is a new install .This may solve your problem.
still no luck
Pete- it came up with check your correct security attributes on the login profile and try again. Any ideas.
Thankyou Pat
Thankyou Pat
