Moderators: Jason Susnjara , Clint Buechlein , Jason Susnjara , Clint Buechlein
DanFecteau
Posts: 278 Joined: Tue, May 10 2005, 12:00PM
Post
by DanFecteau » Wed, Feb 21 2007, 7:35AM
White oak vanity with glaze and distress, all bead was done on the CNC. By the way, what tool do you use to machine those bead on a CNC ?
vanity pin.jpg (270.61 KiB) Viewed 7265 times
Brian Shannon
Posts: 979 Joined: Thu, May 19 2005, 10:50PM
Post
by Brian Shannon » Wed, Feb 21 2007, 10:52AM
Just yesturday, I designed a bead tool to cut the doors and DF's and faceframe all out of one pc of MDF for a paint grade Dresser. I haven't tried it yet on the router. I would like to see the tool use used so I can compare.
Brian
Mark Taylor
Posts: 309 Joined: Sat, Feb 04 2006, 5:13PM
Post
by Mark Taylor » Wed, Feb 21 2007, 6:53PM
Dan...
In cutting the beads on the CNC do you have fixturing to hold down the hardwood? I'm assuming unless you have a beaded cutter you would have to model the bead with a ballnose (?)
BTW - the vanity looks great!
Mark
DanFecteau
Post
by DanFecteau » Thu, Feb 22 2007, 7:40AM
I used a Whiteside # 1572 point round over 1/4\" , but I recently ordered a 3/16\"so my bead will look like my shaper bead better.
Mark Taylor
Post
by Mark Taylor » Thu, Feb 22 2007, 9:24AM
Dan...
so did you assemble the face frame first and then cut the bead on the router?
Mark
DanFecteau
Post
by DanFecteau » Thu, Feb 22 2007, 10:35AM
no, I machined the bead first
