White oak vanity
DanFecteau
White oak vanity
Post by DanFecteau »
White oak vanity with glaze and distress, all bead was done on the CNC. By the way, what tool do you use to machine those bead on a CNC ?
vanity pin.jpg (270.61 KiB) Viewed 7261 times
Brian Shannon
Post by Brian Shannon »
Just yesturday, I designed a bead tool to cut the doors and DF's and faceframe all out of one pc of MDF for a paint grade Dresser. I haven't tried it yet on the router. I would like to see the tool use used so I can compare.
Brian
Mark Taylor
Post by Mark Taylor »
Dan...
In cutting the beads on the CNC do you have fixturing to hold down the hardwood? I'm assuming unless you have a beaded cutter you would have to model the bead with a ballnose (?)
BTW - the vanity looks great!
Mark
DanFecteau
Tool
I used a Whiteside # 1572 point round over 1/4\" , but I recently ordered a 3/16\"so my bead will look like my shaper bead better.
Mark Taylor
Dan...
so did you assemble the face frame first and then cut the bead on the router?
Mark
DanFecteau
bead
no, I machined the bead first
