John Scaravella
Posts: 50 Joined: Tue, Jun 13 2006, 4:13PM
Post
by John Scaravella » Thu, Feb 22 2007, 10:35AM
I am trying to adjust the inset on the top rail of an angle front upper corner cabinet. when I apply a setting of -2 to the left and right setting an inset of -4 appears on the right side. I can't get the left side to move. same happens with the mid rail adjustment. HELP
John
Todd Miller
Post
by Todd Miller » Thu, Feb 22 2007, 1:54PM
John,
Try changing the outside scribe value on the left stile. This will move the vertical left side style, from right to left or vise versa.
What are you trying to accomplish by doing this? I am just curious.....
John Scaravella
Post
by John Scaravella » Thu, Feb 22 2007, 3:14PM
I have inset the top of the styles and I want the top rail to go to the sides of the cabinet. then I will cut an arch in it so the cabinet has an arched top. going to be a bookcase. the styles will be fluted and meet the bottom of the top rail. thanks for the reply, I will give your suggestion a try tomorrow. thanks, John
John
Posts: 5852 Joined: Thu, Jul 28 2005, 10:18AM
Post
by DanEpps » Thu, Feb 22 2007, 3:45PM
John
Why not just use Toggle Overlap? Right on a corner of the face frame (in the Face Frame Editor) and select Face Frame Options -> Toggle Overlap.
Do this for each corner that you want to change.
Toggle Overlap.jpg (71.91 KiB) Viewed 9612 times
John Scaravella
Post
by John Scaravella » Thu, Feb 22 2007, 5:33PM
toggle overlap worked great. Thanks, John
John
Post
by DanEpps » Thu, Feb 22 2007, 5:43PM
I thought you might like that
John Scaravella
Post
by John Scaravella » Fri, Feb 23 2007, 10:13AM
the toggle overlap does not work for the midrail
I am attaching the file
upper corner.hsf
(211.31 KiB) Downloaded 512 times
John
Post
by DanEpps » Fri, Feb 23 2007, 10:19AM
Ummm, why would you want to toggle the overlap on a mid rail? It can't be done on anything but the top and bottom.
Post
by DanEpps » Fri, Feb 23 2007, 10:33AM
Ok, looking at your cabinet, it looks like you want to hav an 8\" top rail. Is that correct?
If so, what you need to do is define a new board stock that is 8\" wide and use that for the top rail.
John Scaravella
Post
by John Scaravella » Fri, Feb 23 2007, 10:44AM
that is what I am going to do. tell me how I did the cabinet I am attaching now. thanks, John
upper 1.hsf
(555.73 KiB) Downloaded 525 times
John
Post
by DanEpps » Fri, Feb 23 2007, 10:59AM
You used all insets on that one. You can inset any rail but you can only toggle overlap on a top or bottom rail.
John Scaravella
Post
by John Scaravella » Fri, Feb 23 2007, 12:59PM
I changed the top rail size t0 7 1/2 stock, worked out fine. just curious why it won't it let me do insets on the corner cabinet like I did on the cabinets in the previous post?
John
