V5.1 Error adding doors
Base cabinet, sheet stock face frames with puzzle joints...
When trying to add CRP-10 double doors I am getting the error in the attached image.
Error Adding Doors.jpg (43.8 KiB) Viewed 6438 times
Update: I removed all part editor cuts from the cabinet and was able to add the doors. I was then able to put part editor cuts back on the cabinet.
Additional information: The CRP-10 doors we configured with a C profile and were inset into the face frames.
Scott G Vaal
Post by Scott G Vaal »
Dan,
Can you please post the cabinet the way it was when you were getting the message? Thanks.
I don't have it anymore but if you try to remove the doors from this one you will get the same error.
Base Assy 1.zip
(1.33 MiB) Downloaded 600 times
Walker T Scott
Post by Walker T Scott »
Dan,
What kind of parte editor cuts did you have on the cabinet and where?
This cabinet has all of the cuts on it. The top has a profiled edge, both ends and both face frame stiles are raised using MDF assymetric #4.
Removing the cuts did not help though until I saved the cabinet WITHOUT the cuts. Once I did that I could add the doors and cuts back to the cabinet.
