Posts: 4764 Joined: Mon, May 09 2005, 7:33PM
Post
by Kerry Fullington » Wed, Mar 14 2007, 8:19AM
This is an Island I am working on and even though I select Gouraud when saving the legs in the Display Part Editor, when I render the view all of the facets show. Is there something I can do to correct this?
Paul Ellis
Posts: 193 Joined: Tue, Jan 17 2006, 1:27AM
Post
by Paul Ellis » Wed, Mar 14 2007, 8:46AM
Kerry,
It looks like your blades you use are blunt!
Paul Ellis
"If it works, don't fix it"
Justin D Melhiser
Post
by Justin D Melhiser » Wed, Mar 14 2007, 8:52AM
Would you post your cabinet and I will take a look at it. Thank you
Post
by Kerry Fullington » Wed, Mar 14 2007, 10:47AM
Thanks Justin,
Island_03.zip
(3.37 MiB) Downloaded 698 times
Mike Seisser
Posts: 544 Joined: Wed, Feb 22 2006, 11:40PM
Company Name: NCB Inc.
Post
by Mike Seisser » Wed, Mar 14 2007, 3:36PM
Kerry,
Are the legs display cubes?
Mike
Post
by Kerry Fullington » Wed, Mar 14 2007, 6:39PM
No Mike,
They are 5X5 legs from a vendor. I couldn't find 5X5 legs from Adams Wood Products.
Post
by Kerry Fullington » Sun, Mar 25 2007, 9:50AM
Justin,
This must be a problem with the number of segments this company used to create their drawings as a turning created using eCabinets still shows facets but they are much smaller and not so distracting.
Mike Snodgrass
Posts: 70 Joined: Mon, Nov 28 2005, 10:12PM
Post
by Mike Snodgrass » Tue, Mar 27 2007, 8:35AM
I've noticed several people are creating turned posts. How is that done? I'm presuming in the part editor with either a display cube or large board stock. But how do you get around the item so that it is round?
Posts: 1896 Joined: Wed, May 18 2005, 7:54PM
Post
by Rick Palechuk » Tue, Mar 27 2007, 11:32PM
Hey Mike, check out some of the stuff by \"Huff\" in the customer tools section, he seems to have a good handle on display items of that nature.
Post
by Kerry Fullington » Sun, Apr 08 2007, 11:47AM
I was able to model a close facsimile using the Shape manager and the part editor. The eCabinet model on the right renders much better than the vendors model on the left.
