While we are on the angle subject
ScotAcree
- Company Name: Scot Acree Woodworkig LLC
In the custom layout in detail room,how do you insert 2 base cabs on 22.5 degree angled walls?I tried free style and that is not very precise.I am trying to get the corner of the ffs to just touch.
Scot
Scot
Todd Miller
ScotAcree
OK that works better,Thank You.
Now, if the middle wall is 54\" and the two side walls are 36\",how do you know what the distance is between the inside corner of the wall and the back corner of the cabinet is when you place the two cabinets together?
Or what math do you use to figure what size cabinet whould go on a 54\" wall at 22.5 degree walls?
Scot
Scot
Todd Miller
Scot,
Highlight the cabinet, then hover over the wall until it turns yellow. At this point a dimension spanning the two entities should appear.
Or take the plan view of the layout into the Line Drawing Editor and dimension that way. Remember to select the cabinets you want before you go into the line drawing editor.
Mike Snodgrass
Is this what you are asking?
If I understand your question, You have 2 cabinets on each side of a 45 degree(135) inside corner.
Pull out your scientific calculator(under the view command, in your windows calculator in your computer).
Each cabinet is at 22.5 degreees,....so enter 22.5 in the caculator.
then hit the tan button
times( *) the depth of the cabinets(24)
the answer is 9.94
I hope this is what you were looking for!
the answer is 9.94
Michael Yeargain
Mike,
Thanks for that tidbit. I never knew the formula myself.
Scott Acree,
This will work for framed cabinets, but will not for frameless; at least to my knowlege. In the pics below you will see the potential problems during install. and customer use. (or should I say NOT use.)
Any how...
Place the two cabinets on the sides first. Now, from the elevation view, select the cabinet and adjust the value in the appropriate fields and press enter.
Then select the two cabinets and a dimemension will appear with the exact measurement needed to fill the space.
Hope this helps.
Thanks again Mike S.
Scott Acree,
Hope this helps.
32Gigs DDR4
NVIDIA GeForce GTX 960 4GB
Corsair RM650
32Gigs DDR4
Corsair RM650
- Denis L'Heureux
- DanEpps
- Company Name: Dan Epps
Re:
The brain damage came from lacquer fumes, DenisDenis L'Heureux wrote:I like that simple method Michael. I was always placing the middle cabinet first and then the to side ones.....of course it was a major cause of brain-damage. This is great.
Cheers
- Denis L'Heureux
Michael Yeargain
Michael Yeargain
just make a cabinet , back only 1/4\" mat 1/4\" wide and place it in the corner. It will snap to the wall but adjust accordingly. You only need to touch one of the nodes
32Gigs DDR4
Corsair RM650
32Gigs DDR4
Corsair RM650
