I gave up
Leo Graywacz
I'm pretty new to this and I started out with V5. It was pretty slow, then I added 2 GB to my computer and it wasn't as slow. Then I did the V5.1.2 upgrade, and the V5 looked speedy. I like the new options in V5.1.2 but not at the cost of that much time. Just making a new seed cabinet, once you insert a drawer it turns into a snail. I've actually screamed at the computer I can make a dovetail drawer as fast as you can compute one. I'm not kidding, I can. Well, just the dovetail routing. That is why I reverted back to V5. Small jobs on V5.1.2 aren't bad, but you just get that one cabinet too many in V5.1.2 and it slows way down.
Dell Precision 7710
NVIDIA Quadro M3000M
512 GB PCIe NVMe - M.2 SSD
Win 7 Pro 64-bit
http://lrgwood.com
Win 7 Pro 64-bit
http://lrgwood.com
- Peter Walsh
Guys,
I want to remind you all that in the latest release, deleting an 'assembly' in the Room Detail Mode is a known problem with a fix staged for the next release.
The workaround is:
In the Detail Room Mode
Select the assembly
Right click and choose \"Edit Assembly\"
In the Editor, delete each component separately
Click on \"Return to Room\"
Choose \"Yes\" to \"Do you want to save the changes to the room.\"
regards,
The workaround is:
Select the assembly
regards,
Leo Graywacz
Re:
I'll try that. Thanks PeterPeter Walsh wrote:Guys,
Dell Precision 7710
Win 7 Pro 64-bit
http://lrgwood.com
Win 7 Pro 64-bit
http://lrgwood.com
Leo Graywacz
The edit assy trick worked but I didn't do incremental saves on my work
and lost 2 1/2 hours of work to an \"OUT OF MEMORY\" error. I guess this hasn't been resolved yet.
Dell Precision 7710
Win 7 Pro 64-bit
http://lrgwood.com
Win 7 Pro 64-bit
http://lrgwood.com
