Batch files
Gerald Boucher
Company Name: Geral Boucher
Batch files
Post by Gerald Boucher »
roll: Can someone tell me if it is possibale to load other items than cabinets or assemblies in the batch cabinets,such as door that can be resized,kickplates,moulding,ect
Ray Jorgensen
Post by Ray Jorgensen »
Gerald,
I needed to figure out how to do this just the other day and found the answer on this forum. I did a quick search and couldn't locate it again but here's the jist of it. It works for doors and drawers, I don't know about the other items you are asking for.
Take a standard base cab with a toe kick - delete everything but the door and the toe kick. In construction settings set the toe kick sizes to 0 and that it has no toe kick. Save the door - it thinks its a cab. You can now batch and resize as you wish.
Follow the same for drawers.
Hope this helps.
Gerald,
You can do the same thing for kicks. Create a cabinet and delete everything but the toe kick and save it. Then you can re-size it as you place it in batch. Anything you save as an assembly can be added to batch.
Gerald Boucher
Ray,
when i do this operation in CE i loss the door . i am running version 5 .1
build 2. i would like to have the door saved as cabinet in batchfile,so i can re-size without going back to CE.
Thank for your reply guy's
Gerald,
Here is the method Ray is talking about listed step by step by Scott Vaal.
As he says \"Follow these to the T\"
\"Follow these to the \"T\"
1.) Load the std base frame less.
2.) Delete all cabinet parts except the toe kick.
3.) Go to door/drawer editor: set the door you want default and then add it to the cabinet (do not change any door con-settings).
4.) Return to main.
5.) Go to con-settings -> toe kick tab: set the Height and Inset to zero, and un-check \"Has Toe\", select OK.
6.) Save this cabinet and then batch any size/Qty door of this style that you want.\"
_________________
eCabinet Systems
Gerald Boucher
Kerry,
Thank you very mutch Kerry works fine
Ray Jorgensen
Gerald, I only get to check the forum in the morning a late at night. Glad that Kerry could clear it up for you and that you got it working.
Ray
