Creating new appliances
Al,
I have the Free Version of Intellicad if you would like it. It is no longer available but I kept the .exe after I upgraded to the full version.
It will do the conversion from .dwg to .dxf then you must open the .dxf in accutrans to convert to .stl
Al Navas
Post by Al Navas »
I accept your offer, Kerry - with a BIG THANK-YOU! That should do it, for sure.
Please let me know how I can go about getting it. WOW! That is a 8) offer, Kerry.
Al
http://sandal-woodsblog.com
Michael Yeargain
Post by Michael Yeargain »
Kerry,
Do you know of a way to batch stl to hsf? (free or cheep) I've done searches, But everything seems to be well over $200.00.
e_cabinets does convert but....
32Gigs DDR4
NVIDIA GeForce GTX 960 4GB
Corsair RM650
Michael,
I haven't found anything to convert to .hsf other than eCabinets. I haven't done a lot of research on it because I like to texture everything in the Display Part Editor.
I used some of the viewers available from Tech-Soft but I finally got rid of them also.
Michael Yeargain
I have 200 files or more, sinks, stoves, fridges, micros etc... and the problem I have is when I convert with Accutrans a DWG into a STL I can only texture the whole item and not individual parts ie... knobs or glass.
Any thoughts?
32Gigs DDR4
Corsair RM650
Paul Ellis
Post by Paul Ellis »
Michael,
If you use Accutrans and you 'Save with options' as a stl (binary), have a look at the 'Flags' section. There you can tick the option 'Write one layer per file'. This gives you multiple files of the object which you can then take into the display part editor and texture seperately. It is quite a lot of work, but you can get results if you are patient!
HTH
Paul Ellis
"If it works, don't fix it"
Michael Yeargain
Paul,
I had only a few minutes this morning to try your suggestions. I will be working with it tonight. I am at the shop for a few days as my truck motor blew, (that blows) and I don't have a running backup right now. I seem to put over 300 mile a week on my vehicles and in doing so I neglect preventive maintenance. BAD thing and a BAD time. :cry:
Preventive maintenance is a GOOD thing. :shock:
32Gigs DDR4
Corsair RM650
