Blind Corner Frameless Base Cabinet
Brent Brown
Post by Brent Brown »
Hi guys.
How are you making your blind corner cabs in e-cabs? I did it before, but now when I try to resize my old cabinet or one from the \"standard\" library I get an error like \"the dimension will result in an unstable cabinet\".
Thank you,
Brent Brown
Michael Yeargain
Post by Michael Yeargain »
Brent,
For a blind Left or Right cabinet I use a 26 1/4\" left or right (respectively) stile of the sheet stock for a face frame. I inset the stile the same thickness of the cabinet material to account for the top and sides. This will allow you to place a door as well as stretch the cabinet without any problems.
The mouse curser is located on a 26 1/4\" left stile inset at the top and left side of this cabinet. I also had to inset the top, sides and deck the same thickness as the faceframe stock.
Hope this helps.
32Gigs DDR4
NVIDIA GeForce GTX 960 4GB
Corsair RM650
Hi Brent
This what I do I make up the face frame then I rout out the
blank side all the way around 3/8\"by 3/8\" and put 1/4\" plywood in it.
It makes our cabinet lighter We are a small shop
NO cnc router :cry:
