drowing an elipse
Nemanja Vujkovic
drowing an elipse
Post by Nemanja Vujkovic »
i am trying to make an elipticel cut out on a door
what is the iziest way to do that
thank you
Post by Forrest Chapman »
Cad/cam
Nemanja Vujkovic
eCabinets in part editor
There is no way to do a true elipse in ecabs. you may be able to create the geometry in cad and export to ecabs only I'm not sure it will machine. I'll take a try later.
Pete Riddle
Post by Pete Riddle »
An ellipse is technically a spline. Since eCabinets part editor does not support splines, you will have to create the appropriate size ellipse in another piece of cad/cam software such as AutoCad or Mastercam, and convert that spline to arcs. Once that is done, you can save it as a dxf and import it into the part editor. It will then work properly.
Nemanja Vujkovic
thanks for your help guys
i am a litle disapointed right now cause before i did start to work on eCabs i did a elipse on the CNC manualy and it worked great
Mark Hesketh
Company Name: Paris Kitchens
Post by Mark Hesketh »
good luck with the elipse. i had to make one months ago and all i remember is that it took me many hours of frustration... and in the end i think it was someone else on the forum that was able to convert my autcad elipse into something ecabs could use for me.
Michael Yeargain
Post by Michael Yeargain »
Nemanja,
What are the actual dims on the elipse you are trying to make? I have Autocad and Acutrans. I may be able to help.
32Gigs DDR4
NVIDIA GeForce GTX 960 4GB
Corsair RM650
