Nemanja Vujkovic
Posts: 222 Joined: Wed, Feb 21 2007, 1:29PM
Post
by Nemanja Vujkovic » Tue, May 29 2007, 3:05PM
cant get this to cut write...profile modeler chews on it for awhile then freezes up..
Joe Soto
Posts: 367 Joined: Thu, May 19 2005, 7:50PM
Post
by Joe Soto » Tue, May 29 2007, 4:07PM
Roger Erismann
Posts: 169 Joined: Sun, Dec 04 2005, 11:42PM
Post
by Roger Erismann » Tue, May 29 2007, 8:11PM
Joe,
I will post the assembly tommorow...nemanja and I work together...
Wood Butcher/Case Maker
Nemanja Vujkovic
Post
by Nemanja Vujkovic » Wed, May 30 2007, 9:24AM
I do not think that .esa file is going to work, so here is one more try.
Joe Soto
Post
by Joe Soto » Wed, May 30 2007, 9:39PM
I just got your files tonight, I will give it a shot in the morning.
Brian Shannon
Posts: 979 Joined: Thu, May 19 2005, 10:50PM
Post
by Brian Shannon » Thu, May 31 2007, 1:04AM
Nemanja,
I've had some very detailed mouldings in PM that I thought had frozen up but it was just taking a loooooooong time. Try it again and just leave it alone for 20 minutes or so. It's worth a shot.
Joe Soto
Post
by Joe Soto » Thu, May 31 2007, 7:28AM
Brian is correct, to verify this I set the step over to a to .125 and it took a no time to verify the tool path or write the code. I'm sure this would not produce a good cut.
Nemanja Vujkovic
Post
by Nemanja Vujkovic » Thu, May 31 2007, 9:48AM
I'm cutting it now. I left it for about 45 minutes and set my step to 0.001, because first time i cut it the step was 0.01 and the cut was far from good. I'll let you now hov it turns out!
Thanks for all your help!
Nemanja Vujkovic
Post
by Nemanja Vujkovic » Thu, May 31 2007, 11:39AM
The part looks great, CNC gave me a litle trouble, but i think that eCabinets is the cause. There is some corupted files!
