Adding 4 hinges automatically
Jason Susnjara
Post by Jason Susnjara »
Our dealer training is finished and the Turkey dealer (Tervelli Ltd. Sti.) showed me how to add 4 hinges automatically. Some members might know about this allready but for the ones that don't, this might be beneficial.
In the Hardware Hole Editor, you will need to add two sets of hinges. However the distance between the two will be fixed (first picture).
Then once you add the hinge to the door you will see what the second pic looks like. The bottom hinge placement is the same as before but the top hinge placement will require a bigger number in order for it to work.
Hope this helps
4 hinge.JPG (160.06 KiB) Viewed 3986 times
HHE-4 hinges.JPG (83.06 KiB) Viewed 3986 times
Jason Susnjara
V.P., Marketing
Thermwood Corp.
On YouTube:
Thermwood Blog:
http://blog.thermwood.com
Thank You Jason
Nemanja Vujkovic
Post by Nemanja Vujkovic »
This is great.
Roger and i just did a job with 115\" cabs, but for the future...
Paul Ford
Post by Paul Ford »
I never thought of doing it that way before.
Thanks very much for the tip!
