Loading old jobs in build 3 question
George L Vought
Post by George L Vought »
I have tried to open 3 old jobs since reinstalling eCabinets in my new computer. I can open them, work on them, but can't save any changes. Anybody else had this problem?
Leo Graywacz
Post by Leo Graywacz »
I have no problems saving the files. I just have problems with editing my cabinets. I get cabinet parts that flip over (decorative toe kick).
Dell Precision 7710
NVIDIA Quadro M3000M
512 GB PCIe NVMe - M.2 SSD
Win 7 Pro 64-bit
http://lrgwood.com
Have you installed the latest update (build 3) George?
Paul Ellis
Post by Paul Ellis »
Tut..tut..tut@Dan
No Dan you disappoint me...look at the Topic heading
(Only pulling your socks....coz those legs I dont touch!
Paul Ellis
"If it works, don't fix it"
Justin Melhiser
Post by Justin Melhiser »
George
Do you get any kind of error message when you try to save?
Re:
Paul Ellis wrote:Tut..tut..tut@Dan
If you look at the time of my post you'll understand--I just hadn't had enough coffee yet :shock:
And what's wrong with my "fuzzy sticks"? :lol: Are yours any better?
Thanks Paul, you woke up Fuzzy Sticks :twisted:
Re:
Rick Palechuk wrote:Thanks Paul, you woke up Fuzzy Sticks :twisted:
I just started my first cup of coffee so I can't think of a snappy comeback---yet. :wink:
Paul Ellis
Oh no Dan you will NOT entice me to show off my own! I believe that your showing off of the original 'Fuzzy sticks\" was peer pressure! I have always been known to go against the stream (= peer pressure!)
George,
My apologies for Net-jacking your original post/problem - hopefully someone will have some sense in answering your question (obviously I am not sensible?/sensitive?/sensational?) Sorry it just sort flows out today...don't listen to me!
Paul Ellis
Daniel Vonderheide
Post by Daniel Vonderheide »
Goerge,
Can you post one of these files so we can take a look at it?
George L Vought
Daniel;
Here is one of the files I couldn't save. I have a couple of others. When I built this version I had the cabinets stored in a folder called My Cabinets. When I reinstalled the program on the new computer that folder was gone too.
Al Navas
Post by Al Navas »
George,
I downloaded the job, moved the microwave, two of the uppers and one of the countertops, then saved the file. Everything saved ok.
Just this afternoon I downloaded and installed Build 4, which is what I used to do this test. I wonder if Build 3 still results in the same problem?
Al
I haven't looked at the job file you attached, but here is my guess. You said you previously stored your cabinet files (HSF) in a directory named \"My Cabinets\" and you no longer have it.
When eCabinets is first installed, it creates only the standard cabinets directory which you cannot save to. You have to create your own directories for your seed cabinets.
If you are trying to save cabinets in the standard cabinets directory it won't work. The job itself references the location of the cabinets in it and is probably looking for \"My Cabinets\".
Try creating that directory (when saving a seed cabinet) and see if that helps.
I opened your job and here is what I was referring to. I was able to save the job with no problems as well but I also have 5.1 build 4 installed.
cabinet 2.jpg (111.55 KiB) Viewed 16129 times
George L Vought
When I'm done with this post, I'm going to download build 4 didn't know there was one :roll:
Ok so if I understand you right Dan, I have to go back in and save all of the cabinets I've ever built (my seed cabinets) into \"MY Cabinets\" folder and the program will then be able to recognize them???? I was afraid it was going to be something this simple :oops: :oops: :oops: :roll: Should I have named the file My seed cabinets????, or is that a personal preference?
