Changing Door Swing In A Wall
Dave Schmidt
Post by Dave Schmidt »
I am having a problem to find a way to change the door swing in a wall. I tried highlighting it and selected rotate. I put in a rotation value however the door remained in the same position. Help is appreciated.
Dave :? :?
Dale,
There is no way to change the hand on eCabinets Passage doors. You can add doors as trim only and make a door from a display cube and the knob from the .stl file in the ecabinets/utilities folder.
Joe Dusel
Post by Joe Dusel »
One thing that should work (but it doesn't) is to change the direction for the wall. This puts both the right and left handed doors in place. Unfortunately the door on the right is floating about 4\" from the wall surface and that does not seem to be movable back against the wall.
Glenn Van Reason
Company Name: TBA
Country: AUSTRALIA
Post by Glenn Van Reason »
I don't do doors so I'm just guessing but can you veiw the wall from the back and put the door in, logic would have that if a door is left hung when placed on the front it would be right hung when viewed from the back, and vice versa.
So for a left for example place it from the front and a right is done by placing it on the back.
