Part Edit Problem?
Michael RA Greschuk
Part Edit Problem?
Post by Michael RA Greschuk »
I'm finding some tops that have editing on them tends to shrink the tenon.any work around would be appreciated
Walker T Scott
Post by Walker T Scott »
Need some more information
What build are you in?
How did you create your part editor cuts?
Were they created from closed contour?
Did you cut to a certain depth or were they cut through?
Did you flip the view before you made the cuts?
Walker
Michael RA Greschuk
Build 4, rec tool, cut through, no flip
Walker T Scott
Michael
I am unable to reproduce this. Are those cabinets saved in that state or can you reproduce this from scratch. I can remove the part editor cuts then re add them without the tenons shrinking.
Walker
Michael RA Greschuk
cant work on reproducing right now Iwill try later to post steps thanks for your help :)
