\"THM needs to close\" in Profile Modeller
Hello,
trying to route raised panels onto an arch, Thm closes every time I select it. Esj & Twd attached, any thoughts would be appreciated.
Sean
Sean
- Arch.esj
- (1.83 MiB) Downloaded 471 times
sean
Sean,
I have taken a look at this and I am having the same problems with the program shutting down. I am using the current version of PM, CN, and ecabs. If you would, send us the parasolid tool file (.x_t) along with profile tool file (.tol). And let us know how you created the geometry for the tool path. (Ex. Did you import a DXF file or did you draw the contour in Ecabs).
Note: Using splines will cause problems. If you are using a different software to create the splines (Autocad,Mastercam, ect.), you will need to convert the splines to arcs before importing them into ecabs.
Send the files requested to program@thermwood.com and we can take a look at them for you.
Todd, Ryan,
running current CN, PM & Ecabs. The contour was created in Ecabs. This tool modelled perfectly on square panels, and will create a tool path for the centre panel which has the same arch top & bottom.
Sean
Sean
- Contemporary Panel Mould 40mm.tol
- (4.34 KiB) Downloaded 469 times
sean
Sean
I will need you to either post or email me the x_t file or dxf file. However you created this shape I will need that. This will allow me to open and take a look at the shape.
My email is cabinets@thermwood.com
Thank You
Justin Melhiser
Thank You
Justin Melhiser
Profile Modeller
Justin,
I used the MDF Asym-3 tool in place of mine & the arch modelled & cut perfectly. But it would be good to know what was wrong with the tool.
Sean
Sean
sean
This issue has evolved due to the fact that the tool has lines that meet at exactly the origin (zero {0}) when it was designed. This is not something we've encountered nor had issue with to this date. This will be added to the issue list for eCab and we will be sure to resolve this situation. However, there is an easy solution to this problem to enable you to produce parts. Simply move the geometry of this tool over by a very small amount (.005\") to get this line to line connection away from the origin. This will eliminate any issue when attempting to create G code at the cnc machine.
Sean
The programmers have narrowed down the problem. It is due to the fact that his tool has lines that meet at exactly the origin (zero {0}). They have never encountered this situation before and they will get this issue added. However, there is an easy solution to this problem: that is to simply move the geometry of this tool over by a very small insignificant amount to get the line to line connection away from the origin. In our example the geometry was moved over in the positive X direction by .005\" and works fine. Any questions, let me know.
Thank You
Justin
Thank You
Justin
