Oval work tops
Kevin M. Williams
Oval work tops
I am having trouble drawing ovals and making them parametric with eCabinetSystems.
- Paul Ellis
Kevin,
Welcome to this forum!
There is not a straightforward way to draw an elipse in Ecabs that I know of.
I think you will find the best answer in this link
http://ntc.thermwood.com/forums/viewtop ... al++elipse
There are other methods as well...do a search for oval OR elipse like I did - look in the 'ecabinets systems software' forum and see if any of the other posts provide an easier way that works for you. You will find that there are always more than one solution for a 'problem'. Whatever blows your hair back, that is the one that you choose!
Paul Ellis
"If it works, don't fix it"
Michael Yeargain
Generaly a wind from the south...Whatever blows your hair back, that is the one that you choose!
_________________
Paul Ellis
Kevin, If you can give me the specs of the oval I can make a dxf file for you to import...
32Gigs DDR4
NVIDIA GeForce GTX 960 4GB
Corsair RM650
32Gigs DDR4
Corsair RM650
