Kevin M. Williams
Posts: 1 Joined: Wed, Aug 01 2007, 2:09AM
Post
by Kevin M. Williams » Fri, Aug 03 2007, 1:05AM
I am having trouble drawing ovals and making them parametric with eCabinetSystems.
Paul Ellis
Posts: 193 Joined: Tue, Jan 17 2006, 1:27AM
Post
by Paul Ellis » Fri, Aug 03 2007, 6:04AM
Kevin,
Welcome to this forum!
There is not a straightforward way to draw an elipse in Ecabs that I know of.
I think you will find the best answer in this link
http://ntc.thermwood.com/forums/viewtop ... al++elipse
There are other methods as well...do a search for oval OR elipse like I did - look in the 'ecabinets systems software' forum and see if any of the other posts provide an easier way that works for you. You will find that there are always more than one solution for a 'problem'. Whatever blows your hair back, that is the one that you choose!
Paul Ellis
"If it works, don't fix it"
Michael Yeargain
Posts: 1740 Joined: Tue, May 17 2005, 8:33PM
Post
by Michael Yeargain » Fri, Aug 03 2007, 3:39PM
_________________
Paul Ellis
Generaly a wind from the south...
Kevin, If you can give me the specs of the oval I can make a dxf file for you to import...
32Gigs DDR4
NVIDIA GeForce GTX 960 4GB
Corsair RM650
